Except some of us live outside America and watched 50Hz CRT TVs for years with no problems.Edmond wrote: Also, 60hz ULMB will flicker so hard your eyes will melt.
I want 60Hz ULMB. No-one's asking you to watch it.
I am also from the part of the world which isnt part of America. And i remember seeing glass filters on CRT monitors.Amalion wrote:Except some of us live outside America and watched 50Hz CRT TVs for years with no problems.Edmond wrote: Also, 60hz ULMB will flicker so hard your eyes will melt.
I believe NVIDIA is currently reluctant to do strobing at 60Hz, due to eye discomfort considerations. If it's done, it would probably end up being an undocumented or advanced user setting (e.g. like a Service Menu setting, or a Blur Busters Strobe Utility setting).masterotaku wrote:Chief, if you're around here, did you tell Nvidia about how good 60Hz ULMB would be? It will be hard to get high fps at this monitor's resolution.
Are there screens with actual 0 lag? I really dont know.flood wrote:ya it will have >0
All i can say with some certainty is that the freesync version will cost 200$ less than the gsync one.Juicebøx wrote:It was briefly talked about in another thread, but I figured I'd ask here... how much do you all expect this monitor to cost? My original budget for a 27" was going to be $700-800... but I will DEFINITELY wait for this beauty instead. It was stated in another thread to expect this monitor to cost $1,200-1,500... is that about right, or should I be saving more than that (for the G-Sync version).
Also, will my GTX 970 be enough of a card to run this monitor, or do I need to upgrade that as well? I realize that running at 144Hz might not be possible on DP 1.2, but will the 970 have enough power to make this monitor "look good"?
