Blur Busters Forums
Impulsive scanning Samsung SVA(Super Vertical Alignment)?
Breaking news in the gaming monitor industry! Press releases, new monitors, rumors. IPS, OLED, 144Hz, G-SYNC, Ultrawides, etc. Submit news you see on the Net!
Re: Impulsive scanning Samsung SVA(Super Vertical Alignment)
Postby Chief Blur Buster » 05 Oct 2017, 11:43
StrobeMaster wrote:
Q83Ia7ta wrote:Samsung rather brazenly tout a 1ms grey to grey response time on these models, which given the panel type to be approached with particular caution.
https://pcmonitors.info/samsung/samsung ... -freesync/
Yes, caution! Because PCmonitors talks about grey-to-grey response time while Samsung just claims a 1ms MPRT (Moving-Picture Response Time), see TECH SPECS in here. MPRT must not be confused with pixel response time. You can get a low MPRT by just using accordingly short strobes for the backlight.
Correct.
To readers, MPRT and GtG aren't the same.
The numbers of the two can diverge a crazily big amount.
A 60Hz non-strobed TN LCD can have 2ms GtG and 16.7ms MPRT.
The only way to get 1ms MPRT without strobing is 1ms refresh cycles (1000fps @ 1000Hz) with no black-time in between. The only way manufacturers are doing "1ms MPRT" now, is to use strobing or scanning backlights, to insert black-time between 1ms frame visibilities -- to avoid the need for unobtainium refresh rates -- to reduce the sample-and-hold effect.
GtG = pixel transition time
MPRT = pixel visibility time (persistence)
By roughly ~2025, we will have 1000Hz gaming monitors (assisted by frame rate amplification technologies), but until then.... "1ms MPRT" is done via strobing.
Previous
Return to News / Rumors / Conventions
Who is online
Users browsing this forum: No registered users and 1 guest
