Graphene Display capable of 400 Hz+
ericl
Post by ericl » 16 Nov 2018, 13:31
This might be interesting tech used in future screens:
https://phys.org/news/2018-11-graphene- ... 00ppi.html
They are saying it could work up to 2000hz! ;)
Re: Graphene flickers at 400hz
Post by RealNC » 16 Nov 2018, 15:00
2000Hz 2500ppi.
Oh yeah :mrgreen:
ericl
Post by ericl » 16 Nov 2018, 16:44
Considering 4k @ 27" is about 163ppi...
And 8k @ 27" is about 335.43ppi..
That would be a hell of a monitor.
Sure, I'll take an 8k @ 27" monitor with 2000hz. Not like we have any graphical hardware that can drive it right now but perhaps in another decade or so.
Kheri
Re: Graphene Display capable of 400 Hz+
Post by Kheri » 18 Nov 2018, 00:19
"Membranes in a graphene MEMS can be moved by applying an electric potential and, together with the large optical absorption of graphene (2.3 percent of visible light)"
2.3% of visible light is a "large optical absorption"? How? Or did they mean 2.3% of the EM spectrum (visible light range on a logarithmic scale).
open
Post by open » 19 Nov 2018, 15:46
They may mean that one layer of the material absorbs 2.3% so a few hundred nm of the stuff can be used as a gate to block light.
Post by Chief Blur Buster » 20 Nov 2018, 13:50
There can be techniques to amplify that 2.3% into something that has a huge contrast ratio. Whether via using polarizers, via using stacking, etc. They will just have to develop the right technique.
Even - LCDs also happen to be nearly invisible without using a polarizer.
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
Post by RealNC » 21 Nov 2018, 11:22
Kheri wrote:"Membranes in a graphene MEMS can be moved by applying an electric potential and, together with the large optical absorption of graphene (2.3 percent of visible light)"
As Chief said, LCD is nearly invisible too. Look at this LCD screen that had its polarizer removed, and then looked through a hand-held polarizer:
https://www.youtube.com/watch?v=xUw3u9lh9rQ
Kheri
Post by Kheri » 21 Nov 2018, 13:03
Thanks to all 3 of you. Actually looking at the Nature article helps a bit too.
