New Laser TV! With flicker?
nuninho1980
Post by nuninho1980 » 09 Apr 2019, 08:52
Hello.
https://www.hisense-usa.com/100l8d :)
At 50/60 Hz, Laser TV with flicker simulates to CRT, ok?
PC specs:
CPU: i7-4790K
RAM: 2x8GB [email protected]
MB: ASUS Z97-Pro Gamer
GPU: EVGA GTX 980 Ti SC+ :D
HDDs: SATA both 1TB+3TB
SSD: OCZ RD400 512GB
PSU: AEROCOOL 1kW 80+ Gold
Disly: CRT monitor 19" Samtron 95p+
Re: New Laser TV! With flicker?
Post by Chief Blur Buster » 10 Apr 2019, 12:38
Depends on the laser implementation.
Most laser TVs are DLP-based TVs, so are effectively sample-and-hold projection displays that are ultra-short-throw. Basically DLP chips illuminted by a laser light source (instead of HID or LED) permitting an ultra-short-throw with minimal lenses. Those won't be low persistence.
Only a few laser projectors are direct scanning based. THOSE are amazingly low persistence, and it was posted here in this 2014 thread. I'm keeping an eye out for higher-definition implementations, as direct-beam laser projectors are practically zero-persistence.
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
