ASUS PG259QN ANNOUNCED! - 360Hz IPS 1ms GtG HDR Monitor with Hardware G-Sync and ULMB Strobing
A Solid lad
Re: ASUS PG259QN ANNOUNCED! - 360Hz IPS 1ms GtG HDR Monitor with Hardware G-Sync and ULMB Strobing
Post by A Solid lad » 13 Sep 2020, 02:21
If you've been waiting forever, 2 more months are nothing. :P
Discord | Youtube | Twitch
canx66
Post by canx66 » 15 Sep 2020, 17:31
like hoolyyy thank you my G! You saved my money. I waiting just to buy the monitor and I thought it has this Reflex Feature. I didnt know, that there 2 Monitors and one without the Reflex Feature. Thank you! The bad news is, I have to wait more :(
speancer
Post by speancer » 15 Sep 2020, 23:08
If anyone wants to know, today I checked out Jamppi's (CS:GO pro player) stream on Twitch while I was browsing CS:GO streams, and I noticed he was using some monitor different than what one would usually see on pro player's desk. I did a quick search and it turns out that professional S-tier CS:GO team ENCE is currently already testing ASUS PG259QN 360 Hz monitor. They are the first high level CS:GO team to switch to 360 Hz IPS. All five ENCE players are using it now, which is also confirmed by prosettings.net. I'd say this is kind of big, I think it's the first time ever CS:GO pros actually use an IPS panel (it's also kind of big that first 360 Hz panel is an IPS one, in fact). It's interesting to me whether ENCE players decide to keep PG259QN or not (or some other 360 Hz IPS in the future).
I remain undecided with my choice, I'd like to test these 360 Hz IPS monitors... and I still have HP Omen X25f and BenQ Zowie XL2546K to test as well.
Main display (TV/PC monitor): LG 42C21LA (4K 120 Hz OLED / WBE panel)
Tested displays: ASUS VG259QM/VG279QM [favourite LCD FPS display] (280 Hz IPS) • Zowie XL2546K/XL2540K/XL2546 (240 Hz TN DyAc) • Dell S3222DGM [favourite LCD display for the best blacks, contrast and panel uniformity] (165 Hz VA) • Dell Alienware AW2521HFLA (240 Hz IPS) • HP Omen X 25f (240 Hz TN) • MSI MAG251RX (240 Hz IPS) • Gigabyte M27Q (170 Hz IPS) • Acer Predator XB273X (240 Hz IPS G-SYNC) • Acer Predator XB271HU (165 Hz IPS G-SYNC) • Acer Nitro XV272UKV (170 Hz IPS) • Acer Nitro XV252QF (390 Hz IPS) • LG 27GN800 (144 Hz IPS) • LG 27GL850 (144 Hz nanoIPS) • LG 27GP850 (180 Hz nanoIPS) • Samsung Odyssey G7 (240 Hz VA)
OS: Windows 11 Pro GPU: Palit GeForce RTX 4090 GameRock OC CPU: AMD Ryzen 7 7800X3D + be quiet! Dark Rock Pro 4 + Arctic MX-6 RAM: 32GB (2x16GB dual channel) DDR5 Kingston Fury Beast Black 6000 MHz CL30 (fully optimized primary and secondary timings by Buildzoid for SK Hynix die on AM5 platform) PSU: Corsair RM1200x SHIFT 1200W (ATX 3.0, PCIe 5.0 12VHPWR 600W) SSD1: Kingston KC3000 1TB NVMe PCIe 4.0 x4 SSD2: Corsair Force MP510 960GB PCIe 3.0 x4 MB: ASUS ROG STRIX X670E-A GAMING WIFI (GPU PCIe 5.0 x16, NVMe PCIe 5.0 x4) CASE: be quiet! Silent Base 802 Window White CASE FANS: be quiet! Silent Wings 4 140mm PWM (3x front, 1x rear, 1x top rear, positive pressure) MOUSE: Logitech G PRO X Superlight (white) Lightspeed wireless MOUSEPAD: ARTISAN FX HIEN (wine red, soft, XL) KEYBOARD: Logitech G915 TKL (white, GL Tactile) Lightspeed wireless HEADPHONES: Sennheiser Momentum 4 Wireless (white) 24-bit 96 KHz + Sennheiser BTD600 Bluetooth 5.2 aptX Adaptive CHAIR: Herman Miller Aeron (graphite, fully loaded, size C)
Conan
Post by Conan » 16 Sep 2020, 00:58
speancer wrote:
15 Sep 2020, 23:08
that is indeed interesting. i'm looking forward to your testing of 360hz and xl2546K. especially their comparison.
first gen of 360hz do seem promising. i just feel they're not quite there yet.
randomgamer
Post by randomgamer » 12 Aug 2021, 13:07
Hi guys,
Just bought this monitor yesterday and i see another setting in Overdrive that I haven't seen in any reviews:
It's called Esports. I am not able to find information about this anywhere. Is this something they have added in newer units with newer firmware?
Post by RealNC » 13 Aug 2021, 03:26
randomgamer wrote:
12 Aug 2021, 13:07
Hi guys,
It's just a label. They could have called it "high" instead. If you want to see the effect of the different overdrive settings, you can view this:
https://www.testufo.com/ghosting
preferafably in fullscreen mode, and then change between the different OD settings. They will affect ghosting.
Post by Chief Blur Buster » 14 Aug 2021, 16:48
IMHO, there should always be a "User Defined" setting in all Overdrive menus nowadays, that allows you to adjust a slider (0 to 100%) that maps to the scaler's entire Overdrive Gain range.
Post by RealNC » 15 Aug 2021, 04:05
Chief Blur Buster wrote:
14 Aug 2021, 16:48
Even a range from 1 to 10 would probably be good enough for virtually all intents and purposes. I suspect the reason we only get settings between 1-3 or 1-4 is not technical, but marketing. Technically, overdrive should be treated the same as brightness, contrast, color saturation, etc. But a slider with values doesn't sound as impressive compared to settings with "ultra", "extreme", "high", etc, in their names :mrgreen:
Nobody245
Post by Nobody245 » 15 Aug 2021, 13:05
Please correct me if I'm wrong, but there is something I don't understand about these new monitors that go over 240HZ:
How do you get 360FPS? As far as I understand, you need your system to be able to deliver the matching number of frames per second to be able to profit from a higher refresh rate and even at 1920 x 1080 an RTX3090 with an i9-10900K can't push past 200-220FPS in most benchmarks I've seen. Also, I'm pretty sure that most game developers don't have such frame rates in mind when developing games, so even setting graphics to potato mode won't make that big a difference.
So g-sync or freesync will just reduce the monitor's refresh rate to match frame rate.
So what's the point of this 360HZ monitor then?
Post by RealNC » 15 Aug 2021, 14:30
Nobody245 wrote:
15 Aug 2021, 13:05
CS:GO, Rainbow Six Siege, and other games like that. If you don't play games that can reach this frame rate, then there's no point in getting such a monitor.
