Does light strobing work well when ~3 fps below ref. rate?
flaviowolff
Re: Does light strobing work well when ~3 fps below ref. rat
Post by flaviowolff » 14 Sep 2018, 22:25
Thank you. Will try the scanline capping soon on my vega 56
flaviowolff
Post by flaviowolff » 15 Sep 2018, 17:11
Thanks again.
Regarding Freesync (so no strobbing), is it recommended to use -3 fps cap, like on g-sync, or is a -0.007 cap better?
ty
Post by RealNC » 15 Sep 2018, 17:57
flaviowolff wrote:Thanks again.
ty
-3 is the safe bet. We didn't test, but it doesn't look like freesync has much reason to be any different from g-sync when it comes to operating very close to the upper refresh rate limit.
