Freesync with Nvidia
lossofmercy
Post by lossofmercy » 22 Aug 2018, 09:20
https://www.reddit.com/r/hardware/comme ... n_amd_gpu/
I recently had an idea while playing the latest WoW expansion. In the game and in a few others these days is the ability to select the rendering GPU. I currently have a GTX 1080 Ti and a Freesync monitor. So I added an AMD GPU I had on hand and connected my Freesync monitor to it. In this case it's a Radeon Pro WX 4100.
With the game displaying and rendering through the AMD GPU Freesync worked as expected. When switching to rendering with the Nvidia GPU Freesync continued to work flawlessly as verified in the monitor OSD while the game was undoubtedly rendered by the 1080 Ti.
This leaves an interesting option to use Freesync through an old AMD GPU. I'm sure there is a somewhat significant performance drop from copying the display to the other GPU but the benefits of Freesync may offset that.
My next thought was to try the the GPU selector that Microsoft added in 1803 but I can't convince it that either gpu is a Power Saving option. https://imgur.com/CHwG29f
I remember efforts in the past to get an egpu to display on an internal Laptop screen but from what I can find there's no great solution to do this in all applications.
*Edit Pictures:
WX 4100 https://imgur.com/a/asaG8Lc 1080 Ti https://imgur.com/a/IvH1tjQ
I also edited my MG279 to 56-144hz range. Still works great.
lossofmercy
Re: Freesync with Nvidia
Post by lossofmercy » 22 Aug 2018, 09:22
Man, if this works with the Samsung TVs... this might be a really useful.
Post by RealNC » 22 Aug 2018, 10:51
If this actually works, I suspect nvidia will lock it down in a driver update soon :P
lossofmercy
Post by lossofmercy » 22 Aug 2018, 12:58
Would be a classic Nvidia move.
BattleAxeVR
Post by BattleAxeVR » 24 Aug 2018, 10:31
IF NVidia can patch this out. I'm not entirely sure, because you can always use a different GPU for rendering than the one connected to the display. Windows internally takes care of surface sharing and duplication.
I guess they use v-sync off? I mean, if you don't have a G-sync monitor attached to the NVidia GPU then it will fail to activate G-Sync, but v-sync off should work and if Windows properly forwards those calls to the AMD-connected display with Freesync then I'm not sure how NVidia could block it without breaking basic Windows functionality.
Typically games will always default to the main monitor but if you can override the GPU that the game uses in this way, then I don't really see what NVidia can do about it. A driver that prevents this hack from working might require roadblocks that make it non WHQL compliant.
If they do manage to patch it out though, I'm working on another solution similar to this idea, that should be bulletproof. But it won't be free.
lossofmercy
Post by lossofmercy » 27 Aug 2018, 17:33
I will wait for people to iron this out. Because this potentially means I will buy a Samsung TV next year.
Post by Chief Blur Buster » 30 Apr 2019, 18:08
It's no longer necessary to use this trick -- NVIDIA now directly supports FreeSync via the "G-SYNC Compatible" mode. The latest drivers make it much easier.
That said, it only works over a DisplayPort cable, not an HDMI cable.
Potentially, an adaptor device with a DisplayID/EDID translator, might be able to translate DisplayPort FreeSync into HDMI FreeSync. But I don't think such a device exists (yet...)
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
tygeezy
Post by tygeezy » 13 May 2019, 16:47
Chief Blur Buster wrote:It's no longer necessary to use this trick -- NVIDIA now directly supports FreeSync via the "G-SYNC Compatible" mode. The latest drivers make it much easier.
It is for Samsung TV's because there is no displayport on their televisions.
Vega
Post by Vega » 14 May 2019, 12:50
Are you saying Freesync (G-Sync) is working with a NVIDIA GPU via HDMI 2.0x on a Samsung TV? Any source?
sharknice
Post by sharknice » 15 May 2019, 09:33
No, he's saying you still have to use an amd integrated GPU and do the windows power saving mode trick to be able to use HDMI freesync.
