Hey BB,
I just got done with my G-Sync build's monitor, but now need to look into a FreeSync monitor for an AMD build that hits ~75fps minimum in its games. Can you recommend some 1080p IPS VRR FreeSync monitors best for supporting 75-200fps range? Games are mostly FPS and other shooters. We are very excited to have our first VRR monitors.
I have read the G-sync 101 articles and various posts here in FreeSync, and assume the same G-sync 101 rules apply to FreeSync (-2fps limit below max hz of monitor in-game or in RTSS [-3fps cap]; V-sync enabled in Radeon control center; V-sync disabled in-game; monitor FreeSync on)
edit: I ended up grabbing the Dell aw2521hfl
New monitor IPS VRR, with 75fps minimums
Re: New monitor IPS VRR, with 75fps minimums
My recommendation is actually a minimum of -3 FPS for both in-game and external limiters across the board. As for AMD FreeSync specifically, since the AMD CP V-SYNC option is only known to work mostly for OpenGL games (to my knowledge), you'd instead want to filp the G-SYNC recommendation, and use AMD CP V-SYNC off + in-game V-SYNC on.ballzley wrote: ↑04 Jul 2020, 03:25I have read the G-sync 101 articles and various posts here in FreeSync, and assume the same G-sync 101 rules apply to FreeSync (-2fps limit below max hz of monitor in-game or in RTSS [-3fps cap]; V-sync enabled in Radeon control center; V-sync disabled in-game; monitor FreeSync on)
Displays: ASUS PG27AQN, LG 48C4 VR: Beyond, Quest 3, Reverb G2, Index OS: Windows 11 Pro Case: Fractal Design Torrent PSU: Seasonic PRIME TX-1000 MB: ASUS Z790 Hero CPU: Intel i9-13900k w/Noctua NH-U12A GPU: GIGABYTE RTX 4090 GAMING OC RAM: 32GB G.SKILL Trident Z5 DDR5 6400MHz CL32 SSDs: 2TB WD_BLACK SN850 (OS), 4TB WD_BLACK SN850X (Games) Keyboards: Wooting 60HE, Logitech G915 TKL Mice: Razer Viper Mini SE, Razer Viper 8kHz Sound: Creative Sound Blaster Katana V2 (speakers/amp/DAC), AFUL Performer 8 (IEMs)
Hi jorimt! glad to have you chime in on method. Will do V-Sync on in-game. If in-game has an FPS limiter already, should I still use RTSS external program to limit FPS too?My recommendation is actually a minimum of -3 FPS for both in-game and external limiters across the board. As for AMD FreeSync specifically, since the AMD CP V-SYNC option is only known to work mostly for OpenGL games (to my knowledge), you'd instead want to filp the G-SYNC recommendation, and use AMD CP V-SYNC off + in-game V-SYNC on.
