Looking at a 1080p FreeSync monitor with a sync range of 40 - 75Hz. If I overclock that monitor to 80Hz via CRU, does it mean I'll also get LFC?
I mean, if the frame rate drop to 39FPS, the monitor can run at 78Hz to compensate for it and so on, correct?
A few videos on YouTube claim that LFC is handled by the GPU and isn't exactly a hardware level feature i.e the monitors are ordinary VRR panels so I think it should work, at least in theory.
Has anyone tested it?
LFC on a 75Hz monitor?
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Electrical Issues Affecting Latency -- Interference, EMI, EMF
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
- ↳ G-SYNC
- ↳ FreeSync
- ↳ XBOX Consoles — ONE / Series S / Series X
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Forum System / Registration / Suggestions
