I am curious what is optimal way to configure AMD Adrenalin for use with a FreeSync monitor.
AMD stated that Radeon Chill automatically matches the Min and Max FPS to the FreeSync range of monitor. So, is it best to leave Radeon Chill at default?
I have also read that the G-Sync 101 settings apply to FreeSync, so is it better to use set max frame rate to refresh rate - 3 fps? If so, is it best to do this via Radon Chill by setting Min = Max = -3 fps or to use FRTC at -3 fps?
Since VSync on AMD only works for OpenGL API, is it best to use Enhanced Sync in driver but then to activate VSync in-game only for OpenGL games?
FreeSync + Radeon Chill: How to set up Chill? FRTC preferred?
Re: FreeSync + Radeon Chill: How to set up Chill? FRTC preferred?
So long as the framerate remains at least 3 frames within the current physical refresh rate, use what limiting method you prefer. In-game limiters are generally 1/2 to 1 frame lower latency than external, whereas external limiters tend to have steadier frametime performance at the cost of slightly higher latency.JasonBlurB wrote: ↑16 Mar 2023, 22:40I have also read that the G-Sync 101 settings apply to FreeSync, so is it better to use set max frame rate to refresh rate - 3 fps? If so, is it best to do this via Radon Chill by setting Min = Max = -3 fps or to use FRTC at -3 fps?
Do note for higher than 240Hz refresh rates, minimum limiting should technically be closer to around 3-5% under the physical refresh rate due to lower frametime tolerances at those scanout speeds.
Use the in-game V-SYNC option with FreeSync. Enhanced Sync is equivalent to Nvidia FreeSync, which is not recommended to be paired with VRR for several reasons:JasonBlurB wrote: ↑16 Mar 2023, 22:40Since VSync on AMD only works for OpenGL API, is it best to use Enhanced Sync in driver but then to activate VSync in-game only for OpenGL games?
https://blurbusters.com/gsync/gsync101- ... ettings/8/
Sorry for necroing, but why does ingame Vsync (in Clash: Artifacts of Chaos) disable my Chill?
Without Vsync I'm limiting to 166 FPS but with I get 170 FPS.
Should Vsync be still enabled in this case?
