Hi ! I've just picked up a 180hz monitor, pretty sweet upgrade from 75hz i must say. Also the first time i get to experience LFC.
After a week i have some questions:
1. As advertised LFC only kicks in when fps is below minimum freesync floor but i have noticed that LFC seems to prefers to engage whenever possible. At 60fps the monitor will refresh 120hz, 72fps 144hz,...and so on while those FPS are well within the Freesync range. Is there a reason for this? What are the notable differences between 60fps at 60hz vs 60fps at 120hz ?
2. I'm very subsceptible to input lag, so i always strictly follow the -3 max refresh rate guide. Now, with LFC, a scenerio where the VRR ceiling can be reach disregard of a frame cap can occur. Say i have a fps cap of 177 and my game runs at 90. As far as i know ( at least my monitor ) will very likely to refresh at 180hz. Will that count as reaching fps = hz and will that horrible, vsynced level of input lag get introduced ?
Some question about FreeSync LFC
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
