Blur Busters Forums
Chief Blur Buster visits AMD's FreeSync room at CES 2015
Re: Chief Blur Buster visits AMD's FreeSync room at CES 2015
Postby nuninho1980 » 09 Jan 2015, 17:10
Chief Blur Buster wrote:It appears to be a browser behavior. The camera's accelerometer (gravity) data is embedded in the photo EXIF header, and some browsers (e.g. Safari) automatically rotate the photos to its correct orientation. But not all web browsers do.
I will need to run a script to hard-code the rotation later -- but for now, I'm blogging everything wirelessly completely from iDevices (for better or for worse).
Ok. I used Google Chrome v39.0.2171.95 running W8.1 x64. ;)
My PC specs:
CPU: Core i7-4790K
RAM: 2x8GB DDR3@2400MHz
MB: ASUS Z97-Pro Gamer
GPU: EVGA GTX 980 Ti SC+ NEW!! :D
HDDs: WD 1TB + 2TB ext-USB
PSU: NOX 1 kW
Monitor: CRT 19" Samsung SM 957MB :D
nuninho1980
Postby hashtonkutcher » 10 Jan 2015, 03:45
How much input lag is all I want to know
hashtonkutcher
Postby sega4ever » 03 Feb 2015, 03:19
Should freesync eventually dominate over gsync, nvidia would support freesync right?
sega4ever
Previous
Return to FreeSync
Who is online
Users browsing this forum: No registered users and 1 guest
