IIyama refresh 144hz - but one time booted with lower value
Posted: 13 Nov 2017, 12:50
by sew333
Hello.
My pc:
6700K stock
*16GB DDR4
*Asus Z170-P
*Corsair 750 RM
*Gtx 1080 Ti Founder Edition
*Monitor Red Eagle IIyama 24' 1080p 144hz plugged by display port cable to GFX.
Maybe this is coincidence and i am worrying about nothing.
Few days ago on afternoon i booted pc fine but i saw that Windows 10 desktop refresh changed itself from 144hz to lower value ( i dont remember to which ) . To restore again 144hz , i turned off monitor ,turned again on.
That happened just once. I remember that this day i had power outage in morning. This was related to power outage or it was coincidence?
Re: IIyama refresh 144hz - but one time booted with lower va
Posted: 15 Nov 2017, 11:20
by jorimt
It's happened to me multiple times before on a GTX 980 Ti, 1080, and 1080 Ti (e.g. same computer, different cards over the past couple years) paired with a single 165Hz XB271HU G-SYNC monitor.
Sometimes I've restarted to find only 85Hz and below selectable. Another restart fixes it.
I haven't had the issue occur since I clean installed the Windows Fall Creators update, but that doesn't mean it won't happen again. I haven't been able to pin down the cause myself yet. Could be a display driver, EDID, cable issue, etc. Not sure.
Posted: 15 Nov 2017, 11:59
by sew333
So that was bug or that power outage related?
But i like i said on my first pc run ( boot ) after power outage refresh was 144hz fine. It happened just after i normally shutdown my pc and booted pc second time.
Maybe coincidence and i am worrying for nothing,hehe ?
So conclusion: It happened not just after ( not on pc first power on ) power outage.
But on second time ( second turn ) when i boot to Windows 10.
PS: I tried to reproduce only 3 times by cutting power to pc and powering on and booting again, but 144hz on start. Not able to reproduce.
Maybe coincidence and i am worrying for nothing?
Posted: 15 Nov 2017, 13:34
by jorimt
It happens on a plain old restart or boot for me every blue moon. I just installed the new Nvidia driver today, and it did it again.
Again, I haven't narrowed down the cause. Could be a number of things, but I doubt it was your power outage that caused or triggered it.
Posted: 15 Nov 2017, 15:03
by sew333
Yes i had power outage. All was fine ,until my second boot ( turning on pc ) after power outage. On first turning on pc , boot after power outage,all was fine 144hz on startup. But when i turn off pc and turn on again, windows 10 booted second time with lower refresh than 144hz. To revert 144hz i just turn off monitor and turn on again.
Just on my second turning ON pc after power outage, it happened. Thats all.
And i am not able to reproduce. Turning off pc few times and booting again,and nothing,still 144hz. Even i cut power 3 times to check,but still 144hz on boot. So maybe that was glitch or something but not related to that power outage?
My drivers: 388.13
Damn sorry for my language. Really apologize.
Posted: 15 Nov 2017, 23:32
by jorimt
I can't reproduce the issue on demand either. Again, it is probably is a bug or a cable transmission issue, and is not caused by power outages (mine is a completely different monitor model than yours and it's G-SYNC, and I have experienced the same thing).
But it's hard to test because it's almost completely random.
Posted: 16 Nov 2017, 04:09
by mello
This problem is quite random, if it happens again revert back to older drivers, that are at leat 6-10 months old. If it doesn't fix the problem, then disconnect pc and monitor from power completely (same with DP cable) for a few minutes, then reconnect DP cable again and power on.
Posted: 19 Nov 2017, 13:21
by sew333
Posted: 26 Nov 2017, 07:17
by sew333
Ok my post up , nevermind. But important question to you jorimt.
In your situation turning off monitor and turning on again resolving 144hz? Or only pc restart?
Like i said i just turn off monitor turn on again and 144hz appeared again.
