Adjusting framerate w/o an AMD card
PostPosted: 10 Apr 2018, 09:01
by rofer
I'm looking to buy a Freesync monitor and I currently have an NVIDIA card. Is it possible to set the monitor to refresh at a constant rate that isn't it's maximum?
I'd like to have tear-free gaming so I will be using v-sync, but at 1440p I won't be able to hit the 144Hz the monitor I'm looking at supports. I'd like to try playing a game, figure out what refresh rate I can reasonably hit, then set the monitor to that. Kind of like a poor-man's g-sync/freesync.
Eventually I'll have a machine with an AMD card and just use freesync, but I'd like to know what my options are until then.
Re: Adjusting framerate w/o an AMD card
PostPosted: 10 Apr 2018, 09:27
by RealNC
Most gaming monitors can operate at any refresh rate you want. All you need to do is use CRU to add the refresh rate you want. I used to do this when I didn't have a gsync monitor yet, and had added 75Hz and 90Hz modes.
Some monitors will not properly support this and will frame skip, but this is very unlikely with freesync monitors.
PostPosted: 10 Apr 2018, 14:06
Yes - generally FreeSync monitors are very multisync.
Usually, any Hz in the VRR range can be created as a fixed Hz. It may sometimes have to derive from a specific dotclock, but success rates of custom refresh rates are very high on FreeSync panels.
