Alienware AW2518HF - Is this behaviour normal?
Shrib
Post by Shrib » 27 Apr 2019, 11:35
Hi,
I'm having some strange issues with my monitor.
I could have sworn that my FreeSync refresh rate counter would change according to the current fps. However now it seems to fluctuate all over the place including over that of the current fps (to 240 when capped at 200 fps for instance). Furthermore, the Overdrive 'response time' setting in the OSD does nothing, there is literally no difference between any of the modes. I've verified this across multiple OS installs with different CRU setups.
https://drive.google.com/file/d/1KO-2cL ... q7mLd/view (at 0.16 I cap the fps to 200)
This is at completely stock settings.
If I remove the display's identifying information using CRU (to render freesync unsupported) then my overdrive settings work again but it's not using the superior calibration that the FreeSync mode provides. Tried different cables, different DP slots.
Input welcome! Thanks
EDIT: Supposedly this fixed FreeSync overdrive mode is normal but I didn't think it looked good in motion, there is overshoot!
MatrixQW
Re: Alienware AW2518HF - Is this behaviour normal?
Post by MatrixQW » 28 Apr 2019, 08:40
FreeSync doesn't keep steady Hz even if the fps are.
About the overdrive:
viewtopic.php?f=2&t=5018&p=40444#p40444
I think this is the same thing I mention, not an issue, just how it works.
Maybe Jorimt or Chief know something.
Shrib
Post by Shrib » 29 Apr 2019, 07:40
Ah good to know it's normal!
apexpr3d
Post by apexpr3d » 31 Oct 2019, 10:09
So when gsync is turned on the overdrive setting does nothing?
Is very fast the same response time/input lag as normal then?
LordsnLadies
Post by LordsnLadies » 06 Nov 2019, 06:59
apexpr3d wrote:So when gsync is turned on the overdrive setting does nothing?
Can't say whether input lag changes, but the overdrive settings do cause slightly worse coronas when gsync is enabled and when you go above normal.
davidoo
Post by davidoo » 07 Nov 2019, 20:05
I own the monitor, and can confirm using the setting super fast on "response time" is literally unplayable because of the coronas.
I stick to normal or -> Fast.
apexpr3d
Post by apexpr3d » 19 Nov 2019, 12:39
Even when using gsync? Changing respone time when gsync is enabled should not incur any coronas, from what I know.
