Does freesync+vsync guarantee no tearing on nvidia?
pc2000
Post by pc2000 » 19 May 2020, 15:53
fowteen
Re: Does freesync+vsync guarantee no tearing on nvidia?
Post by fowteen » 21 May 2020, 02:56
Yes, but you need to activate freesync on your monitor and also activate gsync in control panel, which you can only do though display port
Post by Chief Blur Buster » 22 May 2020, 22:32
Correct, no tearing.
Make sure you use frame rate cap slightly below Hz, to avoid buffer-induced latencies.
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
