BenQ zowie XL2740 Freesync
angryfunk
Post by angryfunk » 25 Aug 2020, 13:31
Hello guys.
I can see in the OSD menu that Freesync is somehow enabled whenever I activate G-sync. When I disable G-sync OSD menu will show 1920*1080p@240hz
I found viewtopic.php?f=13&t=6118&p=45991&hilit=xl2740#p45991 on this forum, he got the same problem. I tried to use CRU to make the monitor FreeSync incompatible i had no luck, I cant edit the monitor range limit.
When I enter games I dont get the G-sync logo.
I uploaded 4 pictures https://imgur.com/a/FvGPnD9
Can someone help me?
