I need help pls about BenQ XL2540 & freesync.
m0m087
Post by m0m087 » 08 May 2021, 08:59
Hi everyone,
I have problem on my setup and i need to fix it pls.
I have the BenQ XL2540 and i play only two games : CS GO & BF5 and the problem is everytime i start BF5 i have the windows sound about USB connection and Freesync appears in menu / system / information of BenQ screen like : modele name : XL2540 / Entrance : displayport / Actuel resolution : 1920x1080 / optimal resolution : 1920x1080 @ 240 Hz / Freesync : enable.
I don't know how to remove this Freesync and it's my problem, now in cs go i feel very bad like big input lag and it's only when i start BF5 because for exemple i start BF5 play close the game i go open the menu of nvidia G sync it's disable i check for enable, re-check for disable apply in Nvidia menu and restart my BenQ screen and after it's good my meny appears like this : modele name : XL2540 / Entrance : displayport / Actuel resolution : 1920x1080 @ 240 Hz/ optimal resolution : 1920x1080 @ 240 Hz.
Can someone help me pls ?
Best regard.
