After formatting "G-SYNC Compatible Indicator" not showing
warface9991
Post by warface9991 » 11 Feb 2022, 06:55
I don't know what happened but after formatting Windows and installing routine things like drivers etc. I guess my FreeSync doesn't work anymore. I don't see fluctuations in monitor's(LG 24GL600-F) OSD which was trying to adjust the Hz and FPS before formatting. I tried reinstalling NVDIA driver via DDU but it didn't help. I use certified DP 1.2. Thanks for your help in advance.
Re: After formatting "G-SYNC Compatible Indicator" not showing
Post by jorimt » 11 Feb 2022, 08:59
warface9991 wrote:
11 Feb 2022, 06:55
Did you try an older driver or the 511.72 hotfix? I ask, because some G-SYNC Compatible users on the Guru3D forums were reporting similar issues with the 511.65 driver.
warface9991
Post by warface9991 » 11 Feb 2022, 09:32
jorimt wrote:
11 Feb 2022, 08:59
warface9991 wrote:
11 Feb 2022, 06:55
Oh it seems that is the problem. I installed a very old driver and it worked. Thanks
Post by jorimt » 11 Feb 2022, 12:06
warface9991 wrote:
11 Feb 2022, 09:32
Good to hear. If you want the newest driver, they recently released a hotfix to correct this issue here as well:
https://nvidia.custhelp.com/app/answers ... /a_id/5320
warface9991
Post by warface9991 » 11 Feb 2022, 19:18
jorimt wrote:
11 Feb 2022, 12:06
warface9991 wrote:
11 Feb 2022, 09:32
Thank you.
Post by jorimt » 13 Feb 2022, 10:50
warface9991 wrote:
11 Feb 2022, 19:18
You're welcome.
