Hi, i get this failure UFO Test VSYNC FAILURE in every test i run.
My setups is
Windows 11 Home 64-bit
CPU HexaCore Intel Core i5-12400F, 4200 MHz (42 x 100)
Cores 6
Threads 12
RAM 16,0GB
GPU NVIDIA GeForce RTX 3060 Ti (8 GB)
HDD NVMe KINGSTON OM8PDP3512B-AA1 (476 GB)
And Display AOC 25G3ZM/BK 240hz 0.5ms
Ive tried Chrome, Firefox, Edge.
What am i doing wrong?
Re: UFO Test VSYNC FAILURE
Wrong forum; moved this thread to TestUFO forum.
Please test www.testufo.com/animation-time-graph
Web browsers are unusually sensitive to background software, so they are an excellent canary in the coal mine for background software that might jitter/stutter your gaming software.
Most common issue is multimonitor. Disable multimonitor, or only use the primary monitor.
Check your System Tray / check your browser extensions.
- Disable all browser extensions
- Reduce the number of startup applications
- Reduce the number of system tray applications
- Have fewer processes in "Task Manager"
- Keep computer plugged in (if gaming laptop)
- Disable power management (High Performance Mode), undo battery-extender optimzations.
