MS Edge shutters..
gganjang
MS Edge shutters..
Post by gganjang » 29 Nov 2023, 22:44
I didn't want to bring another shutter question, but couldn't find any satisfying answer here.
On my tests, MS Edge is always stuck at 60fps though I checked and tried all tips at viewtopic.php?f=19&t=3549 (e.g. hardware acceleration, monitor refresh rate, etc..) while Chrome and firefox shows 144fps well.
I think Edge is supposed to show 100fps according to https://www.testufo.com/browser.html (Please let me know if I'm wrong)
Are there any other shutters on MS Edge that I didn't notice?
User Agent:
Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36 Edg/120.0.0.0
display refresh rate.jpg (91.68 KiB) Viewed 2999 times
animation time graph.jpg (367.57 KiB) Viewed 2999 times
Re: MS Edge shutters..
Post by Chief Blur Buster » 30 Nov 2023, 01:27
The new Edge now supports 480Hz+
Edge should work with GPU acceleration enabled, check edge://gpu
Please post a screenshot of edge://gpu
Also for other readers who google this thread; make sure Control Panel has configured your Display to 144 Hz:
Oh No, I Am At The Wrong Refresh Rate!
Obviously, if Chrome is detecting 144Hz (even if Edge is not), you're already at the correct Hz and it's Edge's fault.
gganjang
Post by gganjang » 04 Dec 2023, 01:47
here's my screenshot of edge://gpu though I checked it already.
If you need further details, I will try to attach the whole report file here.
gganjang
Post by gganjang » 04 Dec 2023, 01:57
Problem solved.
I was turning on 'Vulkan" as graphics backend option in "edge://flags"
As soon as I turned it off, the edge started to show 144Hz
Post by Chief Blur Buster » 05 Dec 2023, 18:07
gganjang wrote:
04 Dec 2023, 01:57
Problem solved.
Yes, Vulkan isn't yet fully VSYNC ON optimized quite just yet. It has an internal 60Hz simulated refresh cycle timer.
Please report this issue at Chromium Bug Tracker.
