Double-Image Effect (Frame Skipping) - Firefox vs Chrome
PostPosted: 03 Jun 2017, 02:07
by baffle
I ran the Blur Busters ULMB test and was super bummed to see that I had bad cross-talk on my Acer XB270HU. I tried the various tests in Chrome at 85, 100, and 120hz and all of them were blurry, including the moving photo test. 120hz actually performed best, contrary to many opinions about lower refresh rates handling crosstalk and ULMB better, but 120hz had no stuttering, it was a nice smooth scroll from right to left, whereas the lower refresh rates were choppy and had even worse blur and crosstalk.
So I decided to try Firefox. Guess what? Almost NO crosstalk! (I'm very happy about that btw!!)
What gives? I'm now questioning if these tests have any validity. Why are my results so different, and which do I trust?
And if Firefox can -improve- my crosstalk, then can other software solutions also improve ULMB?
The Blur Buster strobe utility works only on Lightboost/Benq monitors, but what can we do for an Acer ULMB monitor?
Re: Much Less CrossTalk in Firefox vs Chrome XB270HU
PostPosted: 03 Jun 2017, 06:29
by lexlazootin
Aslong as the colours are the same and the test is in the same position, there shouldn't be any difference in crosstalk at all.
PostPosted: 03 Jun 2017, 14:45
by baffle
lexlazootin wrote:Aslong as the colours are the same and the test is in the same position, there shouldn't be any difference in crosstalk at all.
And yet, there was. A night and day difference. I was ready to send my monitor back after seeing the Chrome results, but the Firefox results have me feeling like I hit the lottery!
PostPosted: 03 Jun 2017, 17:58
by RealNC
If the monitor has crosstalk, it has crosstalk.
Chrome is not able to generate crosstalk. The monitor is. I have no idea what is happening with Firefox, but crosstalk is a monitor artifact, not a software one. If you see it, it's there. It's not been made up.
PostPosted: 03 Jun 2017, 18:16
by baffle
Right, but when running the tests in Firefox, I see very little to no crosstalk. So my monitor is rendering those images with ULMB on and showing those great results. How is that not valid?
If I never used Chrome in my life, I'd only be reporting that my monitor has great ULMB performance and almost no crosstalk (based on my FF results).
Are there any other tests out there? Perhaps an application that doesn't use a browser?
PostPosted: 03 Jun 2017, 19:34
by RealNC
The simplest test is having a black background and moving your mouse cursor over it. Viewing this in fullscreen:
http://jasonfarrell.com/misc/deadpixeltest.php?p=1
and moving your mouse around should give you an indication of crosstalk, which will differ between the top and the bottom of the screen.
PostPosted: 04 Jun 2017, 04:18
by Haste
Just an idea:
What if baffle is experiencing stutters in chrome that he is not experiencing in firefox?
Repeated frames under backlight strobbing operation gives the "double image" artifact. Which looks very similar to strobe crosstalk.
PostPosted: 05 Jun 2017, 04:02
by baffle
RealNC wrote:The simplest test is having a black background and moving your mouse cursor over it. Viewing this in fullscreen:
Very interesting. Again, it renders differently in each browser. How is that possible? I also tried to use a solid black background on my Desktop, and got similar results to Firefox. I saw the pointer lagging behind the middle and bottom of my monitor; and at the top, I could also see a hint of a pointer on both sides. I guess my monitor sucks. :(
PostPosted: 05 Jun 2017, 06:14
by RealNC
baffle wrote:I saw the pointer lagging behind the middle and bottom, and at the top, I could also see a hint of a pointer on both sides. I guess my monitor sucks. :(
No, that's very normal. Blur reduction is not perfect on any monitor. Except on OLED panels. LCD panels always have crosstalk. These tests are extreme cases intended to show LCD crosstalk. The best monitors have less crosstalk, but there is always some of it. No way around it.
Outside of such "synthetic" tests, crosstalk on a good monitor is not very noticeable (when playing games, for example), unless you're actively looking and focusing on it rather than on the game.
PostPosted: 19 Jun 2017, 14:59
Excuse me, let me fix the wild goose & red herring stew...
Let's explain what's going on. Here's my diagnosis (75% confidence factor)
baffle wrote:I ran the Blur Busters ULMB test and was super bummed to see that I had bad cross-talk on my Acer XB270HU. I tried the various tests in Chrome at 85, 100, and 120hz and all of them were blurry, including the moving photo test. 120hz actually performed best, contrary to many opinions about lower refresh rates handling crosstalk and ULMB better, but 120hz had no stuttering, it was a nice smooth scroll from right to left, whereas the lower refresh rates were choppy and had even worse blur and crosstalk.
There are times where browser bugs halves framerates, which creates a perfect double-image effect which looks like very bad strobe crosstalk.
But this isn't strobe crosstalk. It's simply but half-framerate during strobing. Like 30fps@60hz CRT, or 60fps@120Hz LightBoost.
Now in your ULMB 120Hz mode,
Does TestUFO say "60Hz"? Check chrome://gpu (Hardware acceleration needs to be enabled)
Does TestUFO say "120Hz"? Check testufo.com/frameskipping (Browser engine frame skipping)
If you go to http://www.testufo.com/frameskipping -- and see gaps in the squres -- then this is the problem -- the web browser is currently frameskipping at 50%:50%. TestUFO says "120Hz" but it's only showing half the frames whenever the browser incorrectly decides to frameskip. A common cause of browser engine frameskipping is multi-monitor (A 120Hz monitor alongside a 60Hz monitor).
Such every-other-frame skipping will cause 120fps motion to look 60Hz-blurry (in non-strobe mode) or double-image (in ULMB/strobed mode).
To fix this, temporarily disable multimonitor, and run TestUFO only on 1 primary monitor. The problem may disappear.
Now everything's clear.
Happy happy joy joy, eh? :D
(Please follow up if it worked)
