Blur Busters Forums
Testufo BFI Brightness Equalizer
NEW for 2017: Discussion about the www.TestUFO.com Blur Busters Motion Tests. Widely used by enthusiasts, display tweakers, reviewers, monitor manufacturers and VR headset makers!
Postby RealNC » 20 Jul 2017, 23:13
I noticed something weird in the black frame insertion test. The brightness equalizer seems to work fine on my two TN displays. On my IPS, it results in the top UFO being much darker than the bottom UFOs.
I'm curious as to why that is? Is it due to the pixel response difference?
Re: Testufo BFI Brightness Equalizer
Postby Glide » 20 Jul 2017, 23:44
Pretty sure it is response time.
If I recall correctly, changing the overdrive setting on my monitor affected this.
Glide
Postby RealNC » 21 Jul 2017, 00:12
Indeed. Increasing overdrive makes them brigher. The top UFO is still darker though, since they all get brighter with increased OD.
Postby Chief Blur Buster » 24 Jul 2017, 00:44
Two big reasons:
(1) Gamma. The gamma means that full-persistence (non-flickering) UFOs may not be brightness-matched with the flickering UFOs.
(2) Response time. Sometimes the time-to-disappear is unmatched with time-to-reappear, especially with different BFI ratios (e.g. 25%:75% ON:OFF). Overdrive changes the balance, so you will see shifts with overdrive.
Here's http://www.testufo.com/blackframes demo embedded for your viewing pleasure, with a "full framerate UFO" added to bottom:
I've tried my best to make Brightness Equalizer work on the majority of gaming displays, but gamma nonlinearities and response-time nonlinearities will make this impossible. I'll see if I can rebalance the Brightness Equalizer a little more.
Return to Test UFO Motion Tests
Who is online
Users browsing this forum: No registered users and 1 guest
