TestUFO stuck at 60Hz only on chrome
NEW for 2017: Discussion about the www.TestUFO.com Blur Busters Motion Tests. Widely used by enthusiasts, display tweakers, reviewers, monitor manufacturers and VR headset makers!
Diamonds
Post by Diamonds » 02 Jan 2018, 10:31
Chief Blur Buster wrote:Edited Update:
See HOWTO: Fix "TestUFO Stuck at 60Hz" FAQ
Hi,
Before I would say that I've already try everything on this topic : viewtopic.php?f=19&p=28093#p28093
So for me chrome (v.63.0.3239.108) is stuck at 60Hz. I've tryed chrome canary and he is on 144hz.
Here's a chrome://gpu screenshot on chrome : http://prntscr.com/hv5a5r http://prntscr.com/hv5ab6 http://prntscr.com/hv5afa
By the way in chrome canary everything is hardware accelerated.
Re: TestUFO stuck at 60Hz only on chrome
Post by Chief Blur Buster » 02 Jan 2018, 12:20
This is often caused by Chrome's somewhat-flawed GPU-driver-blacklisting behaviour. Sometimes it has good intentions, but for a minor graphics driver bug, it sometimes disables excessively huge numbers of hardware-accelerated features just to get around a teensy GPU driver bug...
Go to chrome://flags and then:
-- "Override software rendering list" = Enable
-- "Accelerated 2D Canvas" = Enable
If that doesn't work, try also:
-- "GPU rasterization" = Enable
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
Diamonds
Post by Diamonds » 02 Jan 2018, 12:46
I've have enable everything, it doesn't work..
Post by Chief Blur Buster » 02 Jan 2018, 16:36
Diamonds wrote:I've have enable everything, it doesn't work..
Ugh! Aren't browser bugs fun?
At least you said the Chrome Canary build works with 144Hz. But what about Chrome Beta?
Diamonds
Post by Diamonds » 03 Jan 2018, 07:25
Chrome Beta works too with 144Hz..
Post by Chief Blur Buster » 03 Jan 2018, 10:22
That's the good news.
Chrome should probably be back to normal for you soon once Beta version number becomes the main release version number.
Post by RealNC » 04 Jan 2018, 04:55
Stable uses its own settings directory. When you install beta or canary, the settings are separate, which might be why they work. So it could be some setting or extension is probably at fault.
Post by Chief Blur Buster » 04 Jan 2018, 21:45
Could be. That said, I've seen Chrome break and repair itself before. I remember a specific version of Chrome 30 that really didn't work well until Beta became the release, then 120Hz/144Hz resumed working. So there's precedent.
Chief Blur Buster wrote:Fixing TestUFO "Stuck at 60Hz" problems
Aka: "TestUFO not working at 144Hz", "TestUFO not working at 120Hz"
TestUFO demands high performance for perfect stutter-free operation. Most web browsers often are stubborn at running at the correct refresh rate, and often stays stuck at 60fps even if you're at a high refresh rate. Unfortunately, web browsers are a very finicky beast, and is often impossible to detect the correct refresh rate in certain web browsers; ending up saying "60Hz" when it is actually 120Hz or 144Hz. That can often happen due to many causes. Several tips are listed at http://www.testufo.com/browser.html but this thread documents more tips.
There are frequent comments about TestUFO being "stuck at 60Hz".
Here are the common solutions:
Doublecheck Control Panel
Verify your monitor is actually running Windows above 60Hz first. You probably already did this, but please doublecheck first before the next step. ;)
Temporarily Turn off Multiple Monitor Mode: Don't Mix Two Refresh Rates
Multiple monitors running at different refresh rates, often interfere with correct TestUFO refresh rate. Make all your monitors all equal to the highest refresh rate, or instead disable multi-monitor.
Laptops Connected To Gaming Monitors
Such as a 144Hz monitor connected to a 60Hz laptop. Close the laptop lid and make the 144 Hz monitor the primary and only monitor.
Use Aero Mode. Don't Use "Windows Basic Mode"
If you're using Windows 7, don't use "Windows Basic Mode". If you're using Windows Vista, don't turn off "Aero".
Try Using Different Browser
TestUFO is currently optimized to work very well with Google Chrome. IE/Edge only runs up to 105Hz, while Chrome runs reliably at 240Hz (if no other applications are running). FireFox also works well (with the stutter fix below).
Fixing Chrome Stutters
Try quitting all applications and windows. Pause your cloud sync (Dropbox) and other background apps. Temporarily reboot in Safe Mode (but enable the graphics driver).
Fixing FireFox Stutters
Occasionally, there are situations where a specific computers only runs 60Hz Chrome but has correct Hz in FireFox. However, FireFox often stutters quite a lot at high refresh rates until you temporarily set minimum CPU to 100%. When adjusted this way, it successfully runs at all current refresh rates.
Check chrome://gpu
Make sure everything is hardware accelerated. Sometimes Chrome will go into software rendering mode that has a 60fps cap.
Check chrome://flags
Sometimes GPU acceleration is disabled. Try enabling GPU acceleration.
Test Balanced Mode or Performance Mode
Power-saving mode may force a browser into a 60Hz mode even with laptops connected to an external display.
Upgrade Graphics Drivers
Sometimes certain web browsers blacklists certain graphics drivers from properly working at full frame rate. A graphics driver upgrade may fix this.
Retest Two Browsers Again
Try both FireFox and Chrome again after you've done all the above (settings tweaks, driver upgrades, etc). Occasionally, one of two web browsers suddenly runs at above 60fps -- so it's best to cover all bases.
Test using native Windows. Don't use a Virtual Machine
Virtual Machines are often stuck at 60Hz. If you are using Parallels or VMWare, please retest natively rather than inside a VM or emulator. Windows works best with TestUFO.
Success? New tips?
Please post what tip fixed your "Stuck at 60Hz" problem. Additional tips will help many users!
Failure?
If you have failed to figure out what to do, please do the following
1. Copy and paste the browser useragent found at bottom of http://www.testufo.com/browser.html
2. Screenshot your Control Panel -> Display refresh rate (or Custom Resolution Utility screen)
3. Screenshot your animation time graph from http://www.testufo.com/animation-time-graph
4. Mention which web browsers you have already tested (retest all browsers after trying all fixes)
