Hello! I am a new owner of the XG2431, and I am quite happy with the quality and performance of the monitor thus far. I have a general question regarding the "PureXP" setting. Is there any potential of this setting shortening the lifespan of the panel? I notice that when you turn it on, the "eco" usage automatically reverts to maximum (100%). I tend to replace computer monitors less than average compared to most users so I would like to do everything I can to preserve this monitor as long as possible. Does backlight strobing put more wear and tear on the panel? Sorry for the wordy/potentially confusing question and thanks in advance!
Not for the XG2431 model specifically.MURDOCK4.1964 wrote: ↑02 Apr 2024, 14:53Hello! I am a new owner of the XG2431, and I am quite happy with the quality and performance of the monitor thus far. I have a general question regarding the "PureXP" setting. Is there any potential of this setting shortening the lifespan of the panel? I notice that when you turn it on, the "eco" usage automatically reverts to maximum (100%). I tend to replace computer monitors less than average compared to most users so I would like to do everything I can to preserve this monitor as long as possible. Does backlight strobing put more wear and tear on the panel? Sorry for the wordy/potentially confusing question and thanks in advance!
The voltage boosting on the XG2431 is much more conservative than on several models such as the XL2546. There are some reports of excess voltage boosted strobe backlights causing LED lumens to go down over the long-term, but this hasn't been reported for the XG2431 model. A study by CREE LED found that you can do a 3:1 boost without appreciably wearing the LEDs down, and the XG2431 only does about a 2:1 boost of brightness.
That way, all lighting including backlights/edgelights including CCFL and LEDs do have a finite lifetime -- whether you use strobing or not. Your brightness will slowly go down over the years. Your maximum brightness today might go down by 25% in five years from now, as one example -- this type of wear will occur regardless of whether you use a strobe backlight or not. This applies to all monitors, a screen purchased 10 years ago typically generally is not able to do the same maximum brightness today -- whether CRT, plasma, LCD (regardless of backlight), OLED.
For longest longevity, you may wish to protect your equipment with some power protection such as an uninterruptable power supply with power-surge/conditioning capabilities. That way, grid disruptions is less likely to disrupt your monitor.
![Image](https://blurbusters.com/wp-content/uploads/2024/01/BlurBustersCollectionBanner-750x80.png)
When did you get a merch store?Chief Blur Buster wrote: ↑02 Apr 2024, 15:04Not for the XG2431 model specifically.MURDOCK4.1964 wrote: ↑02 Apr 2024, 14:53Hello! I am a new owner of the XG2431, and I am quite happy with the quality and performance of the monitor thus far. I have a general question regarding the "PureXP" setting. Is there any potential of this setting shortening the lifespan of the panel? I notice that when you turn it on, the "eco" usage automatically reverts to maximum (100%). I tend to replace computer monitors less than average compared to most users so I would like to do everything I can to preserve this monitor as long as possible. Does backlight strobing put more wear and tear on the panel? Sorry for the wordy/potentially confusing question and thanks in advance!
Thanks chief! I appreciate the fast and informative response. I am generally pretty conservative with my monitors--I actually have the brightness set to zero on this monitor for productivity use! I will use the PureXP feature without hesitation for gaming purposes as it definitely makes a considerable difference. I imagine the decreased brightness from the BFI is still more conservative than leaving it at a static setting with blown out brightness. Cheers!Chief Blur Buster wrote: ↑02 Apr 2024, 15:04Not for the XG2431 model specifically.MURDOCK4.1964 wrote: ↑02 Apr 2024, 14:53Hello! I am a new owner of the XG2431, and I am quite happy with the quality and performance of the monitor thus far. I have a general question regarding the "PureXP" setting. Is there any potential of this setting shortening the lifespan of the panel? I notice that when you turn it on, the "eco" usage automatically reverts to maximum (100%). I tend to replace computer monitors less than average compared to most users so I would like to do everything I can to preserve this monitor as long as possible. Does backlight strobing put more wear and tear on the panel? Sorry for the wordy/potentially confusing question and thanks in advance!
So I got my XG2431 to day and did the LVT trick and strobe utility and this is what I got
The Pixel 3 camera doesn't do it justice, it's a lot clearer in person. This is about 100 Nits.
https://postimg.cc/JHjjQfNB
https://postimg.cc/64CpSw1t
60 HZ completely cross talk free at 4500 VT
![Image](https://i.postimg.cc/wMGR1jXy/Whats-App-Image-2024-04-04-at-11-06-41-PM.jpg)
120HZ very close to cross talk free 2270 VT
![Image](https://i.postimg.cc/vTNXGMDX/Whats-App-Image-2024-04-04-at-11-16-42-PM.jpg)
Quality post right here my god this is EXACTLY the information I was looking for.Discorz wrote: ↑09 Dec 2021, 13:03It's a nice demonstration of what's going on. Even though it doesn't show exact MPRT for each refresh rate like:Chief Blur Buster wrote: ↑06 Dec 2021, 19:03The pulse with value is a percentage of a refresh cycle, and a strobe backlight's pulse width is the MPRT(100%) result.
XG2431 PureXP+:
@60Hz:
Light = non-strobed 150Hz mprt
Normal = non-strobed 200Hz mprt
Extreme = non-strobed 300Hz mprt
Ultra = non-strobed 600Hz mprt
@120Hz:
Light = non-strobed 300Hz mprt
Normal = non-strobed 400Hz mprt
Extreme = non-strobed 600Hz mprt
Ultra = non-strobed 1200Hz mprt
@240Hz:
Light = non-strobed 600Hz mprt
Normal = non-strobed 800Hz mprt
Extreme = non-strobed 1200Hz mprt
Ultra = non-strobed 2400Hz mprt
But due to panels not being able to achieve instant response times actual blur improvements aren't as linear as MPRT, especially at higher refresh rates.
60Hz at PW 25% has almost same blur as non-strobed 240Hz, but isn't as smooth, it flickers and its darker.
- non-strobed 240Hz
- strobed 60Hz PW ∼25%
The fact that I can use this interpolation APP
https://store.steampowered.com/app/9930 ... s_Scaling/
And run any locked 60 FPS game like street fighter at 120 FPS and just enable Pure XP Light and get what is the equivalent of 300 HZ OLED MPRT on what is actually a 60 HZ Game is mind blowing to say the least.
And because fighting games or locked 60 FPS games in general are inherently slow it makes object motion incredibly annoying because you have time to see it being blurred where it just should NOT be so not only does it solve the blur but slow moving objects are also very easy to remove blur.
Strobing really is Amazing
Just bought this monitor. Its shipped today gonna arrive in 2 days. Want to ask this monitor does comes with any hdmi/dp port cable? If it doesn't comes with any cable can i use my old dp port cable comes with vg248?
Yes, it will include a DP cable (at least it has historically been included)
Was stealth-launched this January.
It's still being ramped up slowly with more advertising. Click my signature to browse the UFO merch... From the basic UFO stickers to the ultra-premium Adidas shirt. Thanks for your support!
(For suggestions of additional product, post in the "Suggestions" forum)
XG2431 I bought in september 2022 developed a defect of horizontal lines forming above and below anything drawing on the screen, including the ViewSonic logo during power on. I see a decent amount of posts of this issue on other boards.
I really enjoy the feature set of the monitor. Like I happened to post here earlier the blur reduction with custom QFT can be great at 60-100hz, a nice CRT replacement. But I wonder how long the average XG2431 lasts/return rate.
Interestingly on my unit theproblem has so far been essentially unnoticeable when running at stock 240hz or custom resolutions with maxed out vertical total/pixel clock. At first I thought this might be a strange issue with my PC POST screen. The issue really appears at stock lower hz, or plugged into a console where the screen becomes unusable as it gets filled with horizontal lines that stack up on top of eachother and dont disappear.
If the RMA process goes well from ViewSonic I might replace my 2nd monitor with another XG2431 or splurge on a XG272-2K OLED (BlurBusters verified..?), but better wait for reviews on the latter.
