Hey guys,
I just got the G60SD OLED and its pretty neat. I tried making a 2368x1332 res for 24,5" scaling but making one in CRU Display1.3 didn't show up in nvidia control panel. Also the customize button in nvidia is greyed out. Connected via HDMI2.1.
Any ideas/tips?
Greetz
Samsung G6 G60SD custom res
ASUS VG259QM
SAMSUNG G60SD
Re: Samsung G6 G60SD custom res
The display has forced DSC, regardless of what you do. DSC prevents CRU from working properly.prod1G wrote: ↑15 Jan 2025, 11:41Hey guys,
Any ideas/tips?
Greetz
Try using this: https://www.monitortests.com/forum/Thre ... Editor-SRE
Making a custom res in NVCP might work as well.
SRE did work after full reboot, thanks!
ASUS VG259QM
SAMSUNG G60SD
What happens if i (delete extensions override/disable SCDC present) disable DSC 1.2a in HDMI 2.1 extension? No DSC or just a lower version active?
ASUS VG259QM
SAMSUNG G60SD
I have no clue.
I haven't come across any public data detailing this.
You're on your own, sadly..
