Is Acer Nitro XF252Q best TN 240 hz monitor so far?
Re: Is Acer Nitro XF252Q best TN 240 hz monitor so far?
Got the big brother Xf272x to upgrade my high frequency gaming monitor previously benq xl2540, i consider it an improvement since i no longer have overshoot at the same pixel response times
Good to know, I'll give the 272x a try then! And if I like it, I'll get a second one
I first have to get one of these houses in Greece this summer, but then I'll finally have the space to get myself a real desktop computer with two monitors instead of a laptop.
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
You can use Motion Blur Reduction (VRB Mode,off/normal/extreme 120,144,240hz) with overdrive(off/normal/extreme). vrb and freesync cant be on at the same time.
