Gaming Monitor Recommendation
I sold my g7 odyssey due to the curve and the color uniformity and bad viewing angles . I am using BenQ 2720z now and wanna upgrade to IPS panel I have almost three options the Gigabyte M27QX /LG 27gn850-b and the MSI MAG274QRF without the QD letters . the Lg and the MSI and even the G7 odyssey I had almost have the same price . The M27QX is more expensive by about 100$$ in my country so I want monitor for games like apex legends and watching movies . my main concern now is to get good panel without color shifting and bad uniformity with crisp image . I don't care more about 240hz and the fastest response time cuz I am not a competitive gamer and ill not be . I know people in this forum care about different monitors with almost no blur but I need a decent 1440p 27 display . My option is limited due to my country and prices . something like the PG279QM is too expensive here so I didn't list it . if any display is gonna be released soon with a good price range I can wait . so I am waiting your recommendation
Re: Gaming Monitor Recommendation
I have used and will definitely recommend the Alienware 34 QD-OLED (AW3423DW), a true OLED best gaming monitor for the PC with the 1080p resolution support for a 25 inch screen.
The 34" OLED is fantastic if you can afford it, but it is way out of budget for many -- I'm not 100% sure the OP can currently afford the ferrari of display technologies.
Among 27" 1440p at a budget, I'd impartially recommend almost any of the post-2020 models (165Hz) that you can get affordably in your country. These are the new "Fast" IPS panels that has TN-competitive performance, while having wider color gamut (large portion of DCI P3). The post-2020 manufactured high-Hz IPS is a dramatic IPS performance improvement, that you should try to skip any pre-2020 high-Hz IPS, unless it's an incredible price (sale, or used, etc).
Do you consider the Asus TUF VG27AQ among these? It seems to have been released early 2019.Chief Blur Buster wrote: ↑17 Aug 2022, 17:47The 34" OLED is fantastic if you can afford it, but it is way out of budget for many -- I'm not 100% sure the OP can currently afford the ferrari of display technologies.
For a fantastic gaming experience, I'd highly recommend considering the Lenovo G34w-10 Curved Gaming Monitor. The curved screen wraps around your field of view, providing a more immersive gaming experience and reducing eye strain during long gaming sessions. With a refresh rate of 144Hz, this monitor delivers smooth and fluid gameplay, making it perfect for fast-paced action games and esports titles. The 3440 x 1440 resolution ensures crisp and detailed visuals, allowing you to see every detail in your games with stunning clarity. This monitor is equipped with AMD FreeSync technology, which helps to eliminate screen tearing and stuttering for a smoother gaming experience, especially when paired with compatible AMD graphics cards. It features HDMI and DisplayPort inputs, providing flexibility in connecting to your gaming PC or console. Lenovo is known for producing high-quality products, and this monitor is no exception. You can trust in its durability and performance.
Overall, the Lenovo G34w-10 Curved Gaming Monitor offers an excellent balance of immersive visuals, a high refresh rate, and reliable performance, making it a top choice for gaming enthusiasts.
Hope this helps!
Hope this helps!
