Thank you for this other option, I am trying to find it, but if you are talking about this one: https://www.rtings.com/monitor/reviews/ ... #test_1425Crazyness wrote: ↑11 Feb 2023, 13:05My dear virtual friend..i will only say ..Alvaro Recoba
my solution for every dilemma you have is Acer 390hz 1080p..
I curently run that monitor on Acer Predator XB273U GX 1440p 270hz native timings.
pretty much the same exept Predator is on 10bit..and this tune is on 8bit..
you will not notice any difference regarding 8vs10bit
Predator 1k+ $ and this monitor you can find below 450 i think..
on native 1080p its pretty much as 2566k 360..lets say 85-90% if you want to be nitpicky..
but csgo or any fps more than enough..
mark my words..pretty much efficent for everything you need..
you can make it 4k 144hz without freesync or 120hz freesync premium..
strobing ..HDR400..etc..
i am pretty certain there is no better all arounder sort of say..
jack of all trades ,type of monitor,
it can suit yours every need..
wanna play LOL or Dota make it run like Predator 270hz 1440p
or 4k ..
wanna FPS Csgo Valo..etc
1080p 400hz or lower 720p 540p 400hz..
there is no monitor curently on the market
that can do all of that..
this monitor can do everything with 90% success
and i would rather buy this than any curently especially if you are on a budget
than its no brainer..
wish you all the best with the purchase
It's not available for me T-T not sure why, it really seems amazing.
Alvaro Recoba lol
