Acer Nitro XV252QF 390Hz vs Alienware AW2521H 360Hz vs HP Omen X27 240Hz??
CYCLOPSAG
Re: Acer Nitro XV252QF 390Hz vs Alienware AW2521H 360Hz vs HP Omen X27 240Hz??
Post by CYCLOPSAG » 10 Aug 2022, 13:44
Discorz wrote:
18 Nov 2021, 05:58
If you have AMD card cross out the AW. Some thing you can't use without nvidia card. And G-SYNC is overpriced which you can see if XV and AW prices are compared and they are kinda same monitors.
XV even has a bit less overshoot at max refresh rate but overdrive is not variable like on AW. But for competitive gaming its useless anyways where fps will be high most of the time.
I'm not sure if you'd like to go with TN, old tech but slightly faster response times than these IPS but not as much to be worried about. I guess if you're real sensitive to smallest amount of blur then X 27 would be your choice. Note that its more demanding to run 1440p - less hertz, less fps, more latency... In this case maybe better get other TN monitor.
I'd go with XV252QF.
"more latency"
more latency how? if youre running the same fps same gpu and cpu utilization, how will you get more latency on 1440p compared to 1080p? the omen x27 (1440p monitor) and the omen x25(1080p monitor) have almost the exact same input lag and response times.
Post by RealNC » 09 Nov 2022, 08:45
Arve2AFM wrote:
17 Nov 2021, 07:54
1
wat?
