The post might not be super related here but I'm out of options
I have an acer xf240h and Asus vg245h as my 2nd monitor
Everything was fine when I got the Acer, maybe sometime it will lose connection whenver I started the pc but I saw that it was sort of common and happened 3 times a year max so it didn't bother me.
A couple months ago I moved to a new home, carried my pc and monitors nad made sure nothing happened and 100% they were untouched.
At first everything was fine but after a bit the Acer monitor just turned lost connection(stayed on the whole time) and sometimes it would not comeback at all and I had to restart it or it will go blank for 2 seconds and come back like nothing happened. it can occur every 5 minutes or once every hour seems random to me and it only happens on that monitor.
Now you might think that the monitor is faulty, however it NEVER happenes when my AC is turned off I have no idea how the AC is causing it however, right when it happens I can hear a weird sound from the AC and then the screen goes poof.
I even saw the AC causing my light to turn on for a brief second with the weird sound.
Things I tried: changing the AC/monitor to a different port in the wall, changing DP cables. I also checked the wires inside the AC and they seemed fine.
I'll call some guy who fixes AC's or maybe and electrician but maybe you guys have some ideas that can help.
The weirdest thing is happening to me and I have no idea how to fix it
Return to “General — Displays, Graphics & More”
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
