Persistence After image or ghosting ?
Posted: 14 Jun 2022, 12:38
by yuri
Hello,
I would like to know what you see when you look the yellow paint.
It's look like afterimage due to persistence but some other Say its ghosting i would like to know what is is and how to get rid of it.
Btw it run at 240fps.
https://m.youtube.com/shorts/4MdPd-wZIJc
Re: Persistence After image or ghosting ?
Posted: 14 Jun 2022, 17:18
Yes, it's a form of ghosting/corona. See
LCD Motion Artifacts. Try adjusting your Overdrive setting on your monitor.
Which monitor are you using?
Posted: 15 Jun 2022, 00:54
by yuri
Chief Blur Buster wrote: ↑14 Jun 2022, 17:18
Hello chief,
Well im using the pg279qm its weird because it is the fastest ips panel on the actual market..
Posted: 15 Jun 2022, 01:04
by Discorz
I see only stroboscopic effect and no corona artifacts.
Reference
- Test.png (1.87 KiB) Viewed 2001 times
Stroboscopic effect with no overshoot
- Test OD 0.png (11.39 KiB) Viewed 2001 times
Stroboscopic effect with overshoot
- Test OD 1.png (11.5 KiB) Viewed 2001 times
Posted: 15 Jun 2022, 11:17
by yuri
For me, it's persistence if i Flick my mouse fast, i Can see an afterimage because overdrive does not change anything.. even blur.
Posted: 15 Jun 2022, 16:35
Yes, it may be that too --
Although LCD GtG and overdrive does change the overshoot effects, it does not completely eliminate the stroboscopic effect -- it's well explained at
The Stroboscopic Effect of Finite Frame Rates.
Retina refresh rate (where no further humankind benefit is derived) is not until ~4,000fps at ~4,000Hz for a 24-27" 1080p display, and not until 20Kfps 20KHz for a 180-degree retina-resolution VR headset. Related reading is
Blur Busters Law: The Amazing Journey To Future 1000 Hz Displays.
Posted: 16 Jun 2022, 00:58
by yuri
Does we need to cap framerate if we got frame pacing , frame spikes or frame skips? I mean if in 2seconds you got 200fps 140fps than 80fps does the variable overdrive Can follow like g-sync does or vrr overdrive can't apply an overdrive when frame drop too fast?
Because in Bad optimize games on ultra with no FPS cap you got a lot of frame drop and stutter and its impossible to stablize at 150fps smooth.
Posted: 27 Jun 2022, 06:26
by yuri
If it was stroboscopic effect , why the blue paint does not ghost like thé yellow one, and the overdrive is set to off in this vidéo...
What i am experiencing is a trail/Ghost behind any contrast object when i Flick my mouse fast, its not ghosting because if i move my mouse smoothly it not smear AT all
Even when i set motion Blur i still see this strange effect..
Here if you stare at the snow on the tree you Can clearly see an afterimage of what i see on ALL objects.
even with Blur overdrive g-sync or any kind of settings...
https://m.youtube.com/watch?v=7K8KQd9YD4o
https://m.youtube.com/shorts/RY-3it1WvTk
Does anybody Can help me ?
Posted: 03 Jul 2022, 19:33
by yuri
Still not resolve....
