Hey everyone.
This might not be the perfect place to post this, but I am getting desperate and Y'all seem to be very in the know when it comes to monitors and getting the most out of them.
Long story short: I bought an Lenovo G34w-10 1440P 144hz Ultrawide monitor, and if I attempt to run it at spec, I get chroma subsampling artifacts. I've tried resetting the monitor, forcing it to run at DP 1.4 and even bought a new cable that was (supposed to be) specced for 1.4
I've had to set up a manual 120hz resolution to fall back on in nVidia's Control panel to get the "Most" out of the monitor in spite of this. Monitor is plugged into my 3080 (which has the rebar firmware update if this matters). The weird thing is when I first unpacked and set up the monitor, the trick of setting the panel to DP1.1 and then 1.4 actually worked. But after moving (literally just packed everything down and unpacked it at the other end with no hardware changes) I can't do this anymore.
Does anyone have any experience with this? Lenovo just kind of scratched their heads collectively when I "attempted" to seek support on their end.
Chroma Compression issues at monitor spec (1440PUW 144hz)
Return to “General — Displays, Graphics & More”
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
