Scanline Sync caps 60 fps on high refresh rate
zappthed
Post by zappthed » 23 Jun 2022, 19:09
Hi there! A little help needed using scanline sync.
I was able to make it work when I have 144hz but then I upgraded to 280hz monitor, it just caps my fps to 60 when using the same settings.
Tested it with and without Scanline Sync, and I'm positive it is causing it.
PS. before comments about my ss, I have tried it on exclusive fullscreen either.
zappthed
Re: Scanline Sync caps 60 fps on high refresh rate
Post by zappthed » 25 Jun 2022, 02:31
I'm actually struggling lol
Currently using Low-Lag VSYNC ON method atm
Post by RealNC » 27 Jun 2022, 11:15
zappthed wrote:
25 Jun 2022, 02:31
Are you using two monitors maybe? It might be syncing against the wrong monitor.
zappthed
Post by zappthed » 13 Jul 2022, 11:32
RealNC wrote:
27 Jun 2022, 11:15
zappthed wrote:
25 Jun 2022, 02:31
I can't believe this solved my problem. Thanks!!!
Post by Chief Blur Buster » 13 Jul 2022, 20:33
It's a very common problem. There should be automatic alerts in RTSS to warn multimonitor users.
zappthed
Post by zappthed » 14 Jul 2022, 05:01
Chief Blur Buster wrote:
13 Jul 2022, 20:33
I'm struggling on this tho. Should I disconnect my 60hz monitor every pc restart?
Post by RealNC » 14 Jul 2022, 11:53
zappthed wrote:
14 Jul 2022, 05:01
13 Jul 2022, 20:33
There's a setting in the ini file where you specify which monitor to use for sync.
zappthed
Post by zappthed » 21 Jul 2022, 23:15
RealNC wrote:
14 Jul 2022, 11:53
zappthed wrote:
14 Jul 2022, 05:01
13 Jul 2022, 20:33
I can't seem to find any ini file beside cfg files which is profiles and it is lacking on documentation on how things work.
Really struggling here to make scanline sync work :(
Post by RealNC » 24 Jul 2022, 15:17
zappthed wrote:
21 Jul 2022, 23:15
I believe it's the SyncDisplay setting in the [Framerate] section of the config file. So just add this in the [Framerate] section of your Profiles/Global:
SyncDisplay = N
Where N should be the display you want to sync against, starting from 0. (So 0 is the first display, 1 is the second display.)
