If I want to play FPS competitively, how should I be set up?
zehdah
Post by zehdah » 29 Jun 2022, 02:00
I have an Alienware AW2721d 1440p 240hz Gsync "ultimate" monitor and I'm wondering if I should follow the g sync guide for competitive shooters or turn everything off and uncap frame rate. For everything else I just do the usual Vsync on in control panel, off in game, G sync on, cap to 3 below refresh rate.
sharknice
Re: If I want to play FPS competitively, how should I be set up?
Post by sharknice » 30 Jun 2022, 19:24
Capped with the normal gsync settings. Consistency is king and will be more beneficial than the negligible input lag reduction of completely uncapped and unsynced.
Patrykelele
Post by Patrykelele » 30 Jun 2022, 19:26
g sync is trash safe call
Boop
Post by Boop » 01 Jul 2022, 03:36
I think it really comes down to if you're okay with screen tearing to get a competitive advantage. And if you have a system that is capable of pushing high frame rates.
Are There Advantages to Frame Rates Higher Than the Refresh Rate?
https://blurbusters.com/faq/benefits-of ... fresh-rate
Boomchakadah
Post by Boomchakadah » 02 Jul 2022, 02:39
if you're consistently getting above 240fps, turn off G-sync and cap the fps to something above 240Hz.(preferably a 300fps cap or above)
Otherwise, use G-Sync.
VG258QM 280Hz TN (main)| XG2431 240Hz IPS | XL2540K 240Hz TN | XV252Q 1080p 280Hz IPS | XL2546K 1080p 240hz TN | AW2518HF 1080p 240Hz TN | XV240YP 1080p 165Hz IPS | XG2402 1080p 144hz TN | 27GL83A 1440p 144Hz IPS | XL2411P 144Hz TN | XF240H 144Hz TN
