Benq XL2411Z supports 120hz on HDMI 2.0 or 2.1?
enrigeek
Post by enrigeek » 01 Jul 2022, 03:33
Hello Guys! :-)
I just upgraded my GPU ( RX 6600 ) and it only has display port / hdmi outputs.
Will my XL2411Z ( with no displayport ) support 100/120/144 hz over HDMI 2.0 or 2.1?
Cannot find recent good info on manual or online
Thank You!
ToastyX
Re: Benq XL2411Z supports 120hz on HDMI 2.0 or 2.1?
Post by ToastyX » 02 Jul 2022, 11:11
The XL2411Z does not support 100/120/144 Hz over HDMI. Technically even HDMI 1.4 can do it, but the monitor can't. You will need a DisplayPort to dual-link DVI active adapter, the ones with the USB cable for power. Club3D has one for about $50.
Boomchakadah
Post by Boomchakadah » 07 Jul 2022, 11:27
This is the cable you need https://www.amazon.com/dp/B07T16LLB8
VG258QM 280Hz TN (main)| XG2431 240Hz IPS | XL2540K 240Hz TN | XV252Q 1080p 280Hz IPS | XL2546K 1080p 240hz TN | AW2518HF 1080p 240Hz TN | XV240YP 1080p 165Hz IPS | XG2402 1080p 144hz TN | 27GL83A 1440p 144Hz IPS | XL2411P 144Hz TN | XF240H 144Hz TN
Post by Chief Blur Buster » 07 Jul 2022, 12:52
Even the best new cables won't help a 10-year-old monitor support 120Hz+ on a 60Hz-only HDMI port.
The XL2411Z is almost a decade old, and many monitors in those days were capped to 60Hz on the HDMI jack, regardless of HDMI spec.
mmx_in_orbit
Post by mmx_in_orbit » 18 Feb 2024, 17:55
I see Boomchakadah linked the Club 3D CAC-1010 on amazon. Will the Club 3D CAC-1010-A (apparently the "HDCP OFF" version of the CAC-1010) work just as well for doing 120 Hz 1080p on my Benq XL2411z? My graphics card is nVidia GTX 1080 Ti.
