Viewsonix XG2431 Issue
koookies
Post by koookies » 29 Jul 2022, 13:34
Hello, I recently started having an issue with this monitor when running it at anything below 240hz. I attached an image showing visually what it looks like when the monitor is running at below 240hz. I have already tried resetting the monitor to default settings and PureXP is set to off.
Does anyone know what could be causing this issue or if it is possible to fix it?
