I'm trying to use CRU in combination with NVTimingsEd to get my Samsung Odyssey G7 to "sync" correctly. A kind user here: https://www.mtbs3d.com/phpbb/viewtopic. ... 98#p184698
has gotten it to work with Nvidia 3D Vision but the only problem is, is that there's a syncing issue. The top of the screen will have crosstalk, then the entire screen will look perfect with no crosstalk, then the bottom half will slowly have bad crosstalk eventually fade in, and then it abruptly starts all over from the beginning.
I was told it's most likely a "micro sync" issue and that adjust the frequency in CRU and NVTimingsED may be able to fix it. The more I increase the frequency, the faster the entire cycle I described above happens, ie. each cycle completes quicker but the same behavior occurs.
There seem to be a lot of monitor tech gurus here and am desperate for help. I'm even willing to pay money if I can get this fixed and have 3D working "properly" on my Samsung Odyssey G7.
I also have a Dell S2716DG /S2716DGR (same thing) and an Asus PG27VQ / PG27V (same thing) and the Samsung monitor - when the syncing is correct - has less crosstalk then those other 2 monitors.
I'm really desperate to get the Samsung Odyssey G7 working properly but I have no idea what I'm doing.
Trying to mess around with CRU for "sync issue"
Return to “General — Displays, Graphics & More”
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
