240hz TN options
240hz TN options
Looking for recommendations for a good 24” tn panel. I play only csgo so motion blur is important, currently on a 360hz Alienware ips and although input lag is fast, motion blur is horrendous.
Re: 240hz TN options
Xl2566k 360 tn dyac coming in 4 weeks
| Now: ASUS PG248QP 540Hz. | Past : VG259QM with the Qisda panel/PG27AQN/XL2566K
How do you know is coming in 4 weeks?
Asus VG248QE, Dell S2721DGF, Samsung Odyssey G7 27”, Viewsonic XG2431, XL2546K, MAG251RX, XL2566K.
7800x3D, 7900XTX. Currently on 2556k ama 21, best monitor I have ever used. Waiting for 1440p 360hz (OLED or Zowie)
Maybe in 4 weeks even if it come after 3 months..
Do not buy old 240hz monitor because it will be thrash When 360hz - 500hz TNs come
Hopefully, no more shitty overdrives.
On my 2546K I had to choose between using AMA OFF, with 4.6ms Rise/Fall, or AMA High, 1.7ms but with this amount of overshoot: https://i.imgur.com/zSTnugJ.png.
I'm glad to see that Zowie finally understood that we need granular overdrive control, not just because their 3 options on the 46K model were trash but also to deal with individual panel binning variation.
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
*= currently owned
That actually looks really interesting, cool thanks for sharing. Maybe I'd try the new 360hz TN from them. Currently on a AW2521H, its splendid but not under ULMB which you cannot really tune unfortunately. Nvidiaaxaro1 wrote: ↑08 Aug 2022, 04:55Hopefully, no more shitty overdrives.
