XG271QG Color Settings?
WhyKim
Post by WhyKim » 29 Aug 2022, 15:18
Hello!
I recently bought this monitor and everything is great! The only thing that gripes me is if there was a setting I was missing to make the colors much better. Usually I just follow whatever guide (RTINGS) gives me but since this had no reviews I'm just lost.
Any help is appreciated!
Chop420hz
Re: XG271QG Color Settings?
Post by Chop420hz » 11 Dec 2022, 06:12
Hi there, unrelated question. Does this monitor have pure XP and how does it compare in blur reduction to other monitors of the same specs. 1440p 240hz ips ? ty
Discorz
VIP Member
Post by Discorz » 12 Dec 2022, 04:26
Chop420hz wrote:
11 Dec 2022, 06:12
Might find this helpful: viewtopic.php?p=79090#p79090
