Trying Freesync again with my AMD GPU. No other sync methods like Vsync or Enhanced Sync. Using a Freesync Monitor, and I'm getting something like a stutter but it could be something else like frames dropping.
I've got a moderate overclock on the GPU core ~ 2725MHz and Mem is using Tight Timings and clocked up to 2050MHz. If I run defaults the issues isn't exploited as much. Some have said that it could be the memory error correction; cause I've had the memory clocked higher + tight timings, before. I've also noticed it while not using any sync method at all until I've disabled AMD External Events Utility in Services but it's said the service is needed if using Freesync, so afaik I'm stuck.
So I'm wondering if it's GPU related or Freesync related
Freesync + AMD GPU
- BTRY B 529th FA BN
Return to “General — Displays, Graphics & More”
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
