Asus Monitor showing FPS on right corner
Ram313
Post by Ram313 » 25 Sep 2022, 14:17
Hello, recently my Asus Monitor, model: 27GL83A, started showing the FPS numbers on games on the right side of the
screen monitor and I would like to disble it. I disabled the Nvidia FPS display just to make sure that wasn't it. This monitor
has only one button and its for the brightness. I have no idea how to access any menu on it to see if there were any settings.
Any suggestions would be greatly appreciated.
Boomchakadah
Re: Asus Monitor showing FPS on right corner
Post by Boomchakadah » 30 Sep 2022, 02:32
Press that button.
VG258QM 280Hz TN (main)| XG2431 240Hz IPS | XL2540K 240Hz TN | XV252Q 1080p 280Hz IPS | XL2546K 1080p 240hz TN | AW2518HF 1080p 240Hz TN | XV240YP 1080p 165Hz IPS | XG2402 1080p 144hz TN | 27GL83A 1440p 144Hz IPS | XL2411P 144Hz TN | XF240H 144Hz TN
Discorz
VIP Member
Post by Discorz » 30 Sep 2022, 03:07
If provided model name is correct here is a LG 27GL83A user manual which should help u access the On-Screen-Display (OSD) to disable FPS Counter feature. Check Page 18.
https://www.lg.com/us/support/manuals-d ... ory=OTHERS
Although there is no mention of FPS Counter in user manual it should be under Menu > Game Adjust > FPS Counter.
