Hello. I have just completed my new rig with 3080 strix and Intel 12th gen. So I got myself a pretty capable rig. I love playing highly competitive games, where i don't like having a lot of motion blur. I presented myself with MSI Optix MAG274QRF-QD which didn't meet my requirements. Motion blur knocked me down and I'm going to return it as quick as I can. I got a good PC now, so I would love to play some nice looking AAA titles - that's why I'm going with 144hz rather than 240, cause most of them blur when going with lower frame rate. So... Do you have any suggestions? I really go for a good quality, so if I will have to add some money, I'm down for it. Maybe not like a crazy amount but you know what I mean. I can't wait a very long time too, i gotta return that monitor on Tuesday next week at best ( i have no replacement other than my old tv ). So again
-144hz ( smith like that if 120hz or 165hz option will be better, no problem)
-1440p a must, no ultra wide
- 27" would be great
- flat screen most likely, I've heard that VA's tend to smear although I swapped from a pretty old panel, so I'm used to it a bit (if anyone has a pretty good curved option, i could give it a try)
I would appreciate some solid options, i couldn't stand going through those reviews. One guy says that and the other slams that panel to the ground, as everyone has their own preferences, the opinions vary, so i specified mines.
New Monitor - 144hz 1440p
Re: New Monitor - 144hz 1440p
This is currently the fastest 144hz/170hz IPS monitor on the market. https://pcpartpicker.com/product/Rf2WGX ... kvbmiiprzx
If you find its motion clarity unsatisfactory, you will need to increase your budget and get something like this https://pcpartpicker.com/product/V7VmP6 ... umhx2aaf01
VG258QM 280Hz TN (main)| XG2431 240Hz IPS | XL2540K 240Hz TN | XV252Q 1080p 280Hz IPS | XL2546K 1080p 240hz TN | AW2518HF 1080p 240Hz TN | XV240YP 1080p 165Hz IPS | XG2402 1080p 144hz TN | 27GL83A 1440p 144Hz IPS | XL2411P 144Hz TN | XF240H 144Hz TN
