CRU and BenQ Zowie 2546k 1680 x 1050 @ 240hz
Hey, I am new to the forums and I don't know that much about tech, but I was just using CRU to use a stretch resolution with display scaling and it seems to add a lot of blur. I can minimize some of it with the image sharpening setting found inside the monitor, however there is still blur. It just does not look as good as scaling with the gpu for some reason. I have tried disabling dyac and ama. I was hoping someone a little more knowledgeable could help me out. I am also using exact reduced for all my timings.
- extension blocks with detailed resolutions.png (18.23 KiB) Viewed 1046 times
- cru main.png (37.79 KiB) Viewed 1046 times
