After a long time of research I came to these monitors.
Which one is better in terms of black strobing, who’s more brighter?(I play CS GO in a high lvl)
Which one of them is better in terms lf media consumption?
Which one is the fastest between the two? (Response time and input lag)
These monitors are the only one available in my budget in the UK.
Theres no XG2431 here.
MAG251RX VS 24G2ZU
Re: MAG251RX VS 24G2ZU
I'm new here, and I'm also considering between the two, have you/anyone found an answer yet?
That MSI MAG251RX is among the very first 240hz IPS monitors and it was slower compared to other 240hz IPS. That AOC 24G2ZU has a very low contrast ratio of ~700:1.
I'd get this Dell https://uk.pcpartpicker.com/product/qdF ... or-s2522hg or the ASUS XG259CM
VG258QM 280Hz TN (main)| XG2431 240Hz IPS | XL2540K 240Hz TN | XV252Q 1080p 280Hz IPS | XL2546K 1080p 240hz TN | AW2518HF 1080p 240Hz TN | XV240YP 1080p 165Hz IPS | XG2402 1080p 144hz TN | 27GL83A 1440p 144Hz IPS | XL2411P 144Hz TN | XF240H 144Hz TN
