Hello
I am working as a developer. I work per day 12-14hours, and I want to take care of my eye.
I am currently using Monitor Dell UltraSharp 43 4K, but I think this screen is too much for me, and I want to look at a too-large screen too close (2.5 feet). I also wear special glasses with blue-light filter and use blue-light filter monitor option.
I read many review about monitors, and I think based on two options:
- Gigabyte M32UC - Size 32" Pixel Type VA Max Refresh Rate 160 Hz Variable Refresh Rate Yes Native Resolution 3840 x 2160 HDR10 Yes
- Dell S2722QC - Size 27" Pixel Type IPS Max Refresh Rate 60 Hz Variable Refresh Rate Yes Native Resolution 3840 x 2160 HDR10 Yes
I bought these two monitor, and want one to return, one to leave.
At the moment better for me is Gigabyte, but I readed that IPS for coding is better, right?
VA is most harmful for long-working?
My main goals for new monitor:
- cleary text - 4K in my 43 Dell is very averge
- good for eyes
Monitor for programming/reading - 4K IPS 60hz vs 4K VA 144hz?
Re: Monitor for programming/reading - 4K IPS 60hz vs 4K VA 144hz?
Good question and unfortunately the best might be something like the LG 27GP950, but still so much backlight bleed - so I almost prefer an OLED despite the lower text clarity - just using larger text.
There is nothing that makes VA monitors harmful to your eyes. If you prefer that VA over that IPS, return that IPS.
VG258QM 280Hz TN (main)| XG2431 240Hz IPS | XL2540K 240Hz TN | XV252Q 1080p 280Hz IPS | XL2546K 1080p 240hz TN | AW2518HF 1080p 240Hz TN | XV240YP 1080p 165Hz IPS | XG2402 1080p 144hz TN | 27GL83A 1440p 144Hz IPS | XL2411P 144Hz TN | XF240H 144Hz TN
