Can you do more pursuits of '8QM? With ELMB ON at max Hz and 120Hz. Btw is overdrive locked with ELMB?Kosvill wrote: ↑02 Dec 2022, 08:37D9266046-F763-444E-B07C-A5AD646B8FBA.jpeg
I fell in love with this VG258QM. Comparing to x25 f it looks mostly the same but Asus feels somehow even more responsive when playing Valorant and CSGO.
Picture taken 280fps, Variable OD level 3, 960pps, brightness 20, contrast 80, VRR off, ELMB off
Much better than VG259QM with AU panel, never had Qisda one on 259QM. This VG258QM has Qisda TN panel tho.
Im going to do some more amateur research tomorrow...
Edit. This monitor is giving me some satisfaction first time in a while.
Current monitors: G7 27", Omen X25 f, previous: Asus VG27AQ, VG259QM, LG GP850b, Acer XV27UKV, PG278QR, PG279Q, MG27Q, S2721DGF
Also it would be great if u can test ELMB-SYNC (adaptive-sync ON). But for this better use Smooth Frog because TestUFO does not test VRR range propery. Let me know if u're interested so I can give you quick instructions for the program. It's very similar to TestUFO so it will be easy.
