Best 240hz+ 1440p 27" monitor in terms of motion handling (aside from pg27aqn)
Kennkennykenken
Post by Kennkennykenken » 04 Dec 2022, 06:22
Hey guys, looking for the best 27" 1440p 240hz monitor.
Any suggestions? Googling yeilds pretty generic results, none really specific to motion handling.
I'm coming from the xl2546k so im pretty spoilt for motion handling.
Ideally, pg27aqn seems the best choice but in my country it's basically double the price of all other 1440p 240hz 27" options.
Out of my price range.
Thank you everyone :D
Discorz
VIP Member
Re: Best 240hz+ 1440p 27" monitor in terms of motion handling (aside from pg27aqn)
Post by Discorz » 04 Dec 2022, 08:06
Keep your current XL2546K. Wait another year for prices settle down and new panels to come out.
prod1G
Post by prod1G » 04 Dec 2022, 19:34
Check Discorz UFO database :)
also, while 27" 1440p is not for me, i found the 270Hz Acer XV272UX to be quite good, when i tested it.
VG259QM the GOAT
nolikeee
Post by nolikeee » 05 Dec 2022, 08:28
best 2k 240hz - asus XG27AQM
n3roxe
Post by n3roxe » 06 Dec 2022, 14:17
Im also looking for one, I bought 390hz acer and its damn fast but I dont like the 1080p, colors compared to my older aorus 2k 144hz are worse, the only reason I got this is strobing with almost 400hz but then I dont like how dimm it gets with VBR :)
Is there any 2k 240hz with one of the fast ips panels?
