From the manual, HDMI only support up to 240hz. so 360hz is unlikely to happennolikeee wrote: ↑26 Dec 2022, 09:08I have to update: via HDMI you use custom resolution with 240hz.Faygo wrote: ↑19 Dec 2022, 22:48I'm having the exact same issue on my PG27AQN, you can choose to resize using "Monitor" instead of "GPU" at NVCP then the rest of the resolution will appear but you are still not able to create custom resolution.
and second issue with me is that the monitor limited at 144hz in 1920x1080/2368x1332 resolution, it works fine on windows desktop @360hz. However, when you run into a fullscreen application/game with that resolution the monitor will lock at 144hz. Even you had set it to 360hz at NVCP.
my HDMI cable with monitor not working...so i take 1 hdmi old from another monitor. May be if take good new version via HDMI we can work with 360hz. But now i can use custom with 240hz
PG27AQN cant create custom res in Nvidia panel.
Re: PG27AQN cant create custom res in Nvidia panel.
Does the screen allow you to play in 1920x1440 at 360hz?
current: PG27AQN 360Hz
before: AW2524HF | PG248QP | AW2523HF | PG27AQDM | XL2566K | XV252QF | XG27AQM | VG259QM | 34GL750
I got this monitor and actually in 4:3 aspect ratio the maximum is 240hz. cannot create custom resolution with CRU, everything is blocked
