The G70A gets a display signal lost\black screen for 2 seconds very often during gameplay when you have GSYNC Compatible on and a multi-monitor setup. If you only use the G70A alone with gsync on, you get black screens maybe once every day or so when playing games. Gsync off fixes the problem in general.
A reddit user captured what it looks like on video:
https://www.reddit.com/r/Monitors/comme ... ck_screen/
From my research, because this is a black screen issue and it has to do with gsync compatible, there is a decent chance that the issue is due to the lower side of the freesync range being too low.
Unfortunately I cannot change the range in CRU with this monitor let alone add any resolutions at all.
So i'm stuck after tons of troubleshooting. I've been running my single monitor setup for a while and i'm ready to go back. Does anyone have any ideas?
Windows 10
RTX 3080 ti with latest drivers
DP 1.4 cable from the G70a box.
SAMSUNG 28" Odyssey G70A Black Screen Disconnect\Flicker
Return to “General — Displays, Graphics & More”
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
